420W PTO Bearings and Seals
Jaime in Missis
04-22-2004 10:33:36
Hi everyone. I've been loosing gear oil out of my PTO housing. My father-in-law pulled the PTO housing off and discovered that I need a couple of new bearings.
The needle bearings at the end of the housing were all but gone and we couldn't read the numbers on either of the bearings. Can anyone give me those bearing numbers?
Also, I believe there were some seal(s) to be replaced in there too. Can anyone tell me where I could get those also?
Thanks!
Jaime
Henry J
04-22-2004 11:56:57
 Re: 420W PTO Bearings and Seals in reply to Jaime in Mississippi, 04-22-2004 10:33:36
Jamie
If you were losing considerable oil out from around the pto shaft, you might pay particular attention to the front bearing also. That should be a sealed unit and does not get its lube from the tranny. The front bearing, as I recall is a sealed bearing which separates the unit from the trans/differential.
I don't think you would be saving enough to work on trying to cross out all the parts.
I would hope any respectable customer oriented JD Dealer would pull up that parts picture on the puter and order what you want. The dealer I go to even prints out the sheet sometimes so we can put it on top of the counter and cuss and discuss it.
Good Luck
Jaime in MS
04-22-2004 10:35:33
Doh! forgot to mention the year - 1958.
1958 420W
Thanks!
Wayne in Tn.
04-22-2004 15:20:43
 Re: Re: 420W PTO Bearings and Seals in reply to Jaime in MS, 04-22-2004 10:35:33
Jamie, the outer bearing is number: JD8819T The inner bearing is number: JD7198T The outer seal is number: AM253T
