JD 40 with Wagner Loader
Jason Darrah
04-22-2004 10:09:49
I just got a 1954 JD 40U and it has a WF3-40U Wagner loader on it. Who ever put the loader on connected the hydraulics inline with PTO which doesn't seem to work well at all. When I can get enough oil in the system to actually lift the loader it all spills out of the fill cap under the seat when I bring it back down. I want to hook up a seperate front pump and use the resevoire in the Wagner the way it was intended, which brings me to my question could some one tell me what kind of pump will work with this configuration and where I might possible find it?
andy b.
04-23-2004 18:19:25
 Re: JD 40 with Wagner Loader in reply to Jason Darrah, 04-22-2004 10:09:49
YOU STOLE MY TRACTOR!!!!! !!!!!
seriously, that is exactly what i have. the loader is off it at the present until i finish rebuilding the tractor. on mine there is a metal plate with four pins that fit into four holes with rubber bushings in them in the front engine pulley. then there is a left-hand threaded shaft that threads into the plate, and the end of the shaft is connected to the hydraulic pump. the pump is mounted to a plate on the front of the loader frame. the pump is very small, MUCH smaller than the pump on my log splitter. i'm actually thinking of going with a bigger pump when i get everything back together. i'll go out tomorrow and see if i can find any info on the pump. also, there is a Wagner loader manual you can order here on the YT site. it goes into a good bit of detail on all the Wagner loaders and several backhoe attachments.
andy b.
Jason Darrah
04-26-2004 08:18:46
 Re: Re: JD 40 with Wagner Loader in reply to andy b., 04-23-2004 18:19:25
What year is your 40? I am asking because my pulley has the hand crank on it and its not just a nut that I can take off its all one piece so what I need to know is if I can get a different pulley for the tractor so I can mount a front pump on it?
