730D Installing Main Bearings
Blake
04-21-2004 18:37:15
I am currently rebuilding a 730D ES. I bought the tractor apart and not running. I was wondering 1.) How would be the easiest way to test the injector pump, I have already rebuilt the injectors. 2.) How would be the easiest way to remove the crank and replace the main bearings, also would anyone know how much all three of the mains would cost. Thanks, Blake
Clooney
04-22-2004 03:56:02
 Re: 730D Installing Main Bearings in reply to Blake, 04-21-2004 18:37:15
Blake, you ask...
Quote: 1.) �How would be the easiest way to test the injector pump"...>>> You really can't test them yourself while off the tractor.. You either need to send them out to a Diesel injection shop or put them on a running tractor & see if they perform good & don't leak..
Quote: 2.) �How would be the easiest way to remove the crank and replace the main bearings, also would anyone know how much all three of the mains would cost"...>>> You need to pull both the 1st reduction cover & timing covers, pull the gears from both ends of the crankshaft, pull the starter & top covers, remove the rod caps, remove the L & R main bearing housings, then remove the center main bolts & work the crank out the R/H side.. Not an easy job.. You really need a manual as there is much more to it than just stated.. As far as bearing replacement goes, you need to find the bearings, then press the mains in the old housings then have the bearings machined out to fit your crankshaft. Deere didn�t carry the center main for a while but I think they might now as the aftermarket is now making them.. If no luck at Deere try Albert at Renaissance Tractor [1-800-784-0026]. Albert can answer all your pump questions, parts procurement questions & is very knowledgeable on the Deere 2-cylinder diesels..
~You really need a manual before working on that diesel as those 2-cyl diesel parts are VERY EXPENSIVE & the chance of doing damage while working is high without a manual.. If you don�t want to spend a lot the I&T manual for the Deere diesels actually does a decent job�.
[email protected]
Blake
04-22-2004 12:30:24
 Re: Re: 730D Installing Main Bearings in reply to Clooney, 04-22-2004 03:56:02
Thanks Clooney for all the help. I really appriciate it. Thanks, Blake
