'50 B Crankcase oil selection
Dean
04-21-2004 16:28:50
I bought a '50 B at an estate auction. I don't know what oil is in it now. Any suggestions? I'm in Northwest Ohio. Weight? multi visc? Detergent or non-detergent?
Thanks in advance.
Jim
04-21-2004 16:49:37
 Re: '50 B Crankcase oil selection in reply to Dean, 04-21-2004 16:28:50
This will be contested, but here it goes. Non-detergent. 10W, 20W or 30W or a mix of any. Temperature outside will dictate which to use. I run mostly 10W in the winter and 30W in the summer. I live further north than you. If you find a multi-weight of any of the above, use what you feel is best for whatever the temperature is. Drain ALL the old oil out before you run it any more, put in some fresh oil and run it some. Drain it again, and put some more fresh oil in to flush out it out again.(Filter too)
Your question should be satified with this. Dont get in OIL discussions, it will confuse you and you will end up going by the oldest of 'oil rules'..... .... SLIPPERY OIL IS THE BEST!!!!!
