G and allfuel cylinderhead/block vs 70 gas LP hea
buickanddeere
04-21-2004 13:05:41
The parts CD shows the LP and 70 all-fuel block's cooled water intake from the rad having to take a 90 degree turn and enter the block from the bottom? That can't be right as the 70LP used the same 5-7/8" bore block as the gasser. The CD shows the gasser block's cooling water entrance on the front of the block. The coolant has a straight run from the pump to block coolant entrance. I'm checking out an possible 70 all-fuel over the phone and don't want to purchase it without the 6-1/8" bore block and cylinder head with the G bolt pattern. Some tinker has tossed the small gasoline tank and the all-fuel manifold.Then ran a rude display of tubing from the main tank to the carb without filters, sediment bowl or low pressure oil shut-off. Checking to make certain the savage working on the tractor didn't swap the cylinderblock/pistons and cylinder head on from a gasser as well. I would normally go and look at the 70 gasser in the shed but it's two hours away at the moment.
Jones
04-22-2004 09:29:37
 Re: G and allfuel cylinderhead/block vs 70 gas LP in reply to buickanddeere, 04-21-2004 13:05:41
All fuel came in from the bottom...hard to find.
buickanddeere
04-23-2004 05:33:03
 Re: Re: G and allfuel cylinderhead/block vs 70 gas in reply to Jones, 04-22-2004 09:29:37
The all fuel 70 turned out to be wearing a 70 gas cylinder block, head, manifold and carb. It stared knocking from the flywheel and pulley areas after a few hours as well.
I'm not accusing anybody and it could be a coincidence. However the 70 came from Biewer's Tractor Salvage, located in West Central Minnesota. When called, Biewer's just happened to have a small fuel tank for a 70 all fuel but I just missed an opportunity to purchase an all-fuel 70 block and cylinder head?
