Bearing Cup removal (Clooney)
Henry J
04-21-2004 11:40:29
Clooney, thanks for the tip on runing a bead of weld on the bearing cup to aid in removal on the 420 differential quills.
They popped right out without using a slide hammer after doing a 1 1/2 inch bead on them.
G-MAN
04-21-2004 13:44:54
 Re: Bearing Cup removal (Clooney) in reply to Henry J, 04-21-2004 11:40:29
I much prefer heating the races red-hot in three or four locations perpendicular to the bearing surface, as it has the same effect as welding and there's no possibility of getting welding spatter or slag into assembled components, if you don't have everything apart. Also in our shop, it's easier to find a torch (we have four) than it is to track down the welder, hook it up, etc.
Clooney
04-21-2004 11:46:28
Henry, you�re welcome�That method does work well.. It also leaves the old races intact as they make excellent drivers for the new races..
[email protected]
