Hard starting of John Deere 2010 diesel
Mike Stoike
04-21-2004 11:32:16
I overhauled my 2010 diesel engine about 500 hours ago. I hear that it is a characteristic that they are hard starting engines. Everything is in top shape; battery, starter, alternator. The glow plugs test ok. There is a JD block heater on this tractor and it greatly helps. If it is not plugged in, I might as well not try. I don't like to use starting fluid, but I usually have to give it a small shot. I heard that JD may have updated the cylinger head to help in this matter. Let me know if you have any thing that will help me. Thank you
jdemarisj
04-21-2004 19:26:32
 Re: Hard starting of John Deere 2010 diesel in reply to Mike Stoike, 04-21-2004 11:32:16
What about your primer actuator?
You shouldn't use ether on any engine with precombustion chambers and glow plugs. Ether is fine with other John Deere's that have direct injection, even those that run 22 - 1 compression. 2010 diesel MUST have the following to start properly - #1 a primer assembly that works, #2 initial timing set right, and #3 glow plugs working properly. The primer is essential good starting. 2010s set up properly will start at zero with little trouble.
DON
04-21-2004 12:50:53
DO NOT USE EITHER ON THIS ENGING UNLESS YOU WANT TO OVERHAULE IT AGAIN. THIS ENGINE CARRIES A 20 TO 1 COMPRESSION RATIO AND YOU WILL BLOW THE HEAD GASKET OR WORSE BUST RING LANDS AND BEND RODS. CHECK THE TIMING AND HEAT THE GLOW PLUGS. CHECK THE NOZZLE PRESSURE AND SPRAY PATTERN. IS IT CRANKING FAST ENOUGH ?IT NEEDS TO CRANK 450 RPM. DON
