Dave I am not sure tyhe double lip seal is available. I remember doing those seals on my 420 W which should be the same as your 430. Those big babies are a bunch from JD. Also if you pull out a national seal that JD used it will not have a good national number on it, since JD had them put different numbers on them. Business? oh yeah. Anyway I dug up a cross reference listing that I got from Wayne in TN and he lists the cross over for the AM 939T seal as a Motion Ind. #24932 at about 1/3 of what the ones that come in the green box costs. I think he probably got that brand from Car Quest. Somehow in my book i have listed a Nationa Seal # 410496 as one that fits also. I did put two of those in each side of my 420 but think maybe one would have done it. There was room for the double up. I have been cautioned that if you double up to make sure you pack the space between the two single lip seals with grease since the outside one would probably run dry. As i recall the auto parts store that I went to had a huge book of cross reference numbers and got the national number by starting with the JD number of AM 939T. It sure dried up my axel drip. Good Luck
