3010 oil light
Brad
04-21-2004 05:45:43
I have a 3010 diesel with 8000 plus hours on it. I set the oil pressure to spec with a master guage. When I work her the light comes on under 1200 RPM. Should I be concerned and reset it?
DON
04-21-2004 12:57:12
 Re: 3010 oil light in reply to Brad, 04-21-2004 05:45:43
PULL THE OIL FILTER CAN OUT AND REPLACE IT AND THE O-RING. THEY VIBRATE AGAINST EACH OTHER AND WEAR OUT THE O-RING. WHAT WEIGHT OIL YOU ARE USEING MAKES A DIFFERENCE. ALSO FUEL DILUTION WILL DROP OIL PRESSURE AS WELL. MIGHT CHECK THE OIL LEVEL FIRST TO SEE IF YOUR MAKING OIL.
Tony
04-21-2004 05:55:15
I have a 3020D that the gen light does the same thing until it is reved up and puts out more power. Try and put a gauge on it and just ease your mind and get the psi reading. Best of luck, and plow on.
