420 Quill Bearing Cup removal?
Henry J
04-20-2004 17:30:06
Anyone ever removed the bearing cups from the Quills of a 420W?
There is no place/room to get behind them for drifting.
The only suggestion I had so far is to weld an arc about 1/3 around inside on the cup, let it cool and is should almost fall out.
Anyone pulled these out before? I would appreciate suggestions.
Thanx
Clooney
04-20-2004 17:51:56
 Re: 420 Quill Bearing Cup removal? in reply to Henry J, 04-20-2004 17:30:06
Henry, I have only done one 420 for quill bearings & that was a while ago.. I just welded a washer in the race, then welded a nut to the washer & when it cooled & shrunk a little they came right out with a slide hammer..
[email protected]
