'50 B Gear Shifting Trouble
Dean
04-20-2004 15:57:33
About 50% of the time I have difficulty shifting gears on my tractor. I pull back the clutch lever and can pull it out of gear but pushing the lever into another gear is met with grinding. I reduce the throttle and can jam it into gear. But this can't be good for the 54 year old machine. Other times I can easily move from gear to gear. Is this a clutch related problem? Is my clutch not disengaging when I pull back on the lever?
Kerry
04-20-2004 19:30:54
 Re: '50 B Gear Shifting Trouble in reply to Dean, 04-20-2004 15:57:33
I don't know how familiar you are with these old tractors with the hand clutch, but it's pretty normal to have minor "problems" getting them into gear. No, you shouldn't have to fight with it, but I've owned several and sometimes you have to slip the clutch just a bit to get it into gear. The transmission doesn't have a syncronizer like a car. If it won't go into gear (and you don't have something in a bind), put it all the way back to neutral, push the clutch lever forward just a little - enough to barely move the belt pulley - then pull the handle back and try it again. It will probably go right in.
If that doesn't do it, hold the shifter handle with a little pressure on it like you were still trying to put it into gear, and slip the clutch a little bit by pushing the clutch lever forward just barely. You might not even see the pulley turn much, but it will move enough to let it drop into gear.
All this assumes you don't have anything major wrong with the transmission. Once you do it a few times, you'll get the hang of it. It happens more if you have some kind of PTO-driven equipment that might be putting a little bit of a bind on the transmission.
If you've been running these old machines for a million years, you've already tried all this so nevermind! ;-)
Kerry
Clooney
04-20-2004 17:47:01
Dean, try adjusting the pulley brake up tighter.. If the pulley brake is a little loose it will allow the clutch to re-engage when the hand lever is pulled to the rear. If that clutch doesn't completely release you will have a very hard time shifting gears..
[email protected]
