Need information on wheels/tires for a 2020
Rod
01-25-2004 18:57:06
I have recently purchased a 2020 with a loader and I have not had any experience with a John Deer. I would like to put smaller wheels and wider rear tire on this thing. I think that it has 11.2-36/10-36. It has the heavy weight wheels and narrow tires on it. I think it is a row crop tractor. I sure would appreciate any information on what kind of wheels and tires that I can switch to, if any? Thanks in advance for any information.
Rod
02-09-2004 08:17:30
 Re: Need information on wheels/tires for a 2020 in reply to Rod, 01-25-2004 18:57:06
Thanks David for the information. I lost this site and just got back to it.
David
01-25-2004 20:28:44
I've got a couple 2020s. Tire size depends on your model (LU, RU & HU) of 2020, with 36 inch wheels I'm guessing you have an HU model? Do you have rack and pinion or flange wheels? Let me know and I'll give you the range the service manual suggests. An owners manual would be a good investment, along with a parts manual.
David
Rod
01-26-2004 16:22:09
 Re: Re: Need information on wheels/tires for a 20 in reply to David, 01-25-2004 20:28:44
Dave thanks for taking the time to answer. I don't know a lot about the JD. Have used an old case for a long time and bought this one for the loader. Ser#050----- type looks like 5HIC. As I know it I have 36" cast iron wheels and the whells fit on the axel with about 12" protuding out from the wheel. That axel has a long groove and small groves that run the other direction from the first. They seem to be bolted from behind and in front of the wheel (next to the tractor and away from the tractor. I am not sure if I am telling you the right thing or not, but I hope so. I have asked a new dealer and a used dealer (salvage) and neither could or WOULD tell me what I can do. I sure would like to find different wheeels if possible. Sorry that I could not state this any better, but if it will help you to know what I need I sure would like to have the help. Thanks again, and in advance.
Rod
David
01-26-2004 17:50:09
 Re: Re: Re: Need information on wheels/tires for in reply to Rod, 01-26-2004 16:22:09
Rod, You have a 1967 HU model 2020 with rack and pinion axles. HU stands for High Utility and was the tallest 2020 made for crop clearance. It came with 30 and 36 rear wheels. If you want to keep your tractor original, you can replace your 36 inch setup with a 30 inch system. Without consideration for selling your existing setup, replacing your cast wheels (that's the center part), your rims (the outer part the tire is mounted to) and tires would run around 1500. The hardest part will be finding new cast centers as they not available from the dealer, only salvage yards. If you want to lower your tractor for stability, I'd suggest going to a 16.9 X 30 setup which is around 59 inches tall. I've got 16.9 X 28s, which is around 57 inches tall on one of mine w/ a loader and it works fine. Before you do anything, go to ebay and pick up an original JD owners manual and JD parts manual, you won't regret it! Does your 2020 exhaust through the hood (vertical) or out the back (horizontal)? Drop me an email and I'll send you some pictures. Hope this helps...
David
