4010 Diesel problem
Rudy in Tx
04-20-2004 05:02:16
I just got a 4010 Diesel that the engine over-revved.The owner put it in 8th gear and held the brakes and got it stopped. Where do you think I should start working to correct this problem? It has not been started since this happened. Thanks for any help.
Rudy in Tx
04-20-2004 10:23:50
 Re: 4010 Diesel problem in reply to Rudy in Tx, 04-20-2004 05:02:16
The guy I got it from thought he got it shut down before it damaged the engine. The engine turns over but won't know if it is damaged until futher examination. Thanks for the info !
JDGnut
04-20-2004 15:07:12
 Re: Re: 4010 Diesel problem in reply to Rudy in Tx, 04-20-2004 10:23:50
I think everyone has you on the right track on the pump... 2 Questions.. Does it have an M&W turbo installed??? Does it still have the crankcase air pump installed on the left side of the engine.. with the line running into the intake??? JDGnut
Rudy in Tx
04-20-2004 19:21:48
 Re: Re: Re: 4010 Diesel problem in reply to JDGnut, 04-20-2004 15:07:12
It doesn't have a M&W turbo on it and it does have the pump with the line running into the intake. I talked to the man I got it from today and he said when he put it in 8th gear and stalled it out that it went backwards instead of forwards. I don't know if that means anything or not. Thanks
JDBert
04-20-2004 06:37:55
You probably know this already but I'll say it anyway DO NOT START AGAIN it'll just do it all over again. Did you get it shut down before it caused any engine damage?
Jim B
04-20-2004 05:34:04
Rudy,the govenor ring in inj.pump probably failed.Time to send pump to Inj.pump repair shop.Be sure and get in time before removal.Jim B
Bob
04-20-2004 05:29:49
1.) Defective governor in injection pump.
2.) Crankcase overfull with oil/diesel fuel getting sucked into engine.
3.) Oil bath air filter overfull and oil getting sucked into engine.
