Disk for a 60
Willy
04-20-2004 03:33:37
What size disk was recommended for a 1955 JD60?
Also what model number would have been available from JD in 1955? Thanks Willy
Larry
04-21-2004 09:23:20
 Re: Disk for a 60 in reply to Willy, 04-20-2004 03:33:37
Gary,
We use a pull type 8' 2 gang offset John Deere disk made by Kileffer. It has a spring on the hitch, hydraulic lift and one wheel on one side and 2 wheels on the other. It works good, but really works the 60.
Larry
Gary Myers
04-20-2004 17:30:55
When I was a young fellow on my Dad's farm in Southern Saskatchewan we had a JD 60. We used diskers then and we pulled a 12 foot disker with our 60. 15 feet would have been too much.
Willy
04-21-2004 03:12:02
 Re: Re: Disk for a 60 in reply to Gary Myers, 04-20-2004 17:30:55
Hey Gary what is a disker?
Gary Myers
04-21-2004 03:34:20
 Re: Re: Re: Disk for a 60 in reply to Willy, 04-21-2004 03:12:02
A disker, or what they used to call a 'one-way' has one set of disks set up so that you pull them through the field on an angle. (30 degrees?, I'm guessing). They have a seed box for grain and before air seeders were the prime implement for seeding, later on in the year they were used for summerfallowing. One thing I remember is you couldn't turn to the right with a disker, the front wheel would 'over-centre' and you'd need to jack it up to set it back. As I said earlier, a JD60 would pull 12 feet, a 70 was good for 15 feet and the 80 would haul 18 feet. One-ways in the old days came as small as 6 feet. Can you imagine heading into a 40 acre field with a six foot one-way?
Dean VP
04-20-2004 10:51:15
In John Deere's Sales brochure "Matched Working Equipment" double gang disks up to 8' are recommended for the 60. It shows two integral disks to be used with an 800 series hitch. The model KBY and KHZ. A pull behind KBA or KBL would also be period correct.
