4430 steering UK tractor
charles
04-20-2004 00:40:45
This tractor has the later steering valve block under the hood , the problem is that although the steering is perfect while the engine is running , the steering wheel spins freely with no effect on the front wheels when it's not , I know this is not a problem , but I worry that if I break down in a field far from the farm then towing it home will be impossible , incidently it is a quadrange with hydro FWA . The manual gives 4 possible faults 1 Metering pump return oil check valve
2 metering pump internal leakage
3 steering valve manual steering valve 4 Steering valve make up valve I think that I can rule out 1 because the manual says that this condition also causes "lumpiness " and an up/down motion in the steering wheel with 2 I would expect some low level of effect on the front wheels ,With 3 do i just undo the 2 large nuts at each side of the valve and extract the springs etc? Where is 4? Make up valve ??? ( do Deeres wear make up ?) I cannot find this valve Sorry it is so longwinded Where is the problem most likely to be ?? T.I.A.
david val
04-22-2004 05:43:30
 Re: 4430 steering UK tractor in reply to charles, 04-20-2004 00:40:45
when towing the tractor you have to turn the wheel A LOT to get some steering. actually you steer with the little hand pump that works on the main large steering cylinder. always steer while the tractor is moving.
david
