620 won't idle down
48 G Nate
04-19-2004 21:19:24
Hello.
Have a 620 that runs great and has good power. Has been running fine, but now sometimes it won't idle down at all from full throttle, and other times it will idle down some, but not all the way. Looked things over, can't see anything visibly wrong.
Thanks in advance
Nate
48 G Nate
04-20-2004 22:06:50
 Re: 620 won't idle down in reply to 48 G Nate, 04-19-2004 21:19:24
As far as I can tell, there is nothing wrong with the governor spring or the linkage and nothing seems to be binding up. I am puzzled here.
Thanks
Nate
Clooney
04-21-2004 03:57:53
 Re: Re: 620 won't idle down in reply to 48 G Nate, 04-20-2004 22:06:50
Nate, I doubt it's the governor lever spring as that spring speeds it up not slows it down.. The governor is what slows it down.. If that spring was broken or cracked it would not want to rev up but would always want to run slow.
~Start by MAKING SURE the linkage rod between the governor arm & carb throttle lever is adjusted.. To do that hold the governor lever & carb at wide open & adjust that front rod to be � to 1 holes short of entering the carb lever hole..
~Once the linkage is adjusted & set correctly & checked AGAIN for any binding on the fuel tank, brackets, carb lever cotter pin, or pivots, then look for other problem areas..
~If you have the later 620 it will have a �� screw through the governor arm.. Make sure that screw is adjusted correctly as that allows the hand throttle to push the carb to idle when the hand throttle is pulled to idle.. [I don�t have the adjustment procedure handy but it�s in the book] .. If you look at it & move the hand throttle you will see how it works..
~Other than that, try removing the linkage rod from the carb lever, then operating the carb by hand [engine running] while holding pressure on the front [removed] throttle rod.. You should be able to get the carb to smoothly go from idle to wide open & back to idle with ease & also feel a smooth even pull on the linkages rod as you operate the carb by hand.. If the rod action is jerky, non linier, lazy, or erratic then you probably have governor problems..
[email protected]
48 G Nate
04-21-2004 18:37:18
 Re: Re: Re: 620 won't idle down in reply to Clooney, 04-21-2004 03:57:53
Thanks Clooney, will try this out.
buickanddeere
04-20-2004 16:39:19
Any cracks in the govenor's flat external spring?
DON
04-20-2004 12:34:33
CHECK THE COTTER PIN ,AT THE CARB., ON THE ROD TO THE GOVERNER FOR BINDING. IF IT IS INSTALLED WRONG IT WILL LOCK THE THROTTLE ROD.
Chris
04-20-2004 10:15:36
First thing I would do is make sure the linkage isn't binding up between the governor and the carb.
