GPA open fan shaft
Paul
04-19-2004 21:18:37
I just bought an early 1934 General Purpase Open Fan Shaft A with the early GP serial number plate. It has a crack in the transmission case starting at the right brake. I checked around and found another transmission case with the 1934 heat casting in it with no serial number plate on it for 150.00.How hard is it to remove the serial number from mine and put it on the other case and how is this done. I dont want to risk damaging my tag removing it. I do think I could weld the case although it would take some time. thanks Paul
BMAN
04-21-2004 07:02:42
 Re: GPA open fan shaft in reply to Paul, 04-19-2004 21:18:37
What's the serial number of your GPA?
Dwayne
04-20-2004 15:34:30
the serial tag on a GPA is larger than the others, so you will only use the front rivet hole and will have to drill a new rear one. what is your number?
Don
04-19-2004 21:49:07
Paul, I have had pretty good luck on the three or four tags I have removed. I take a Dremel tool and cut a slot into the head of each pin making it like the head of a screw. Cut them as deep as you can without touching the SN tag. Place the blade of a good fitting screwdriver in to the slot. Turn the screw driver counter clockwise with a set of channel locks while applying preasure against the screw so the screwdriver doesn't slip out. The pins have spiral flutes on them allowing them to work kind of like screws. So far I have had a 100% success rate doing it this way. These pins are very hard to drill out. As the other poster mentioned, new pins are available from your JD dealer.
jason r
04-19-2004 21:22:18
you can remove your tag with a chisel or like tool. the rivets are still available from deere. you will have to drill out the old rivets from the other case but they will work
