3020 remote hyd.
Craig
04-19-2004 20:16:25
I acquired a 3020 diesel today and when it arrived I noticed that it does not have any remote hydraulics. Can I add this to the tractor some way? Also between the two gear shifts is another lever,,,I can't seem to find its function,,,can anyone help me with this also?
Brokenwrench
04-20-2004 04:46:12
 Re: 3020 remote hyd. in reply to Craig, 04-19-2004 20:16:25
I think you have a utility model,not a 3020,2030 maybe?. 2 gear shifts between your legs? The lever between the gear shifts is the independent pto.Remote(s) can be added by installing a control valve and breakaway coupler. Try salvage yards around you,but you will need the correct model number. The valve,coupler mounts and lines are common to a number of utility models.
