3020 D electrical problem
jdman(MO)
04-19-2004 19:32:17
Any idea why the 10 gauge wire from the positive termnal to chassis ground would burn up. Replaced it and everything works fine. Russ
Guitarzan
10-21-2005 04:14:47
 Re: 3020 D electrical problem in reply to jdman(MO), 04-19-2004 19:32:17
ET, I am also having elect problems with my 3020 and have decided once and for all to fix them. (good luck, huh.) I now have no gen and idiot lights w/the switch turned on. Which battery should the ground strap be hooked to left or right (from viewed from rear of tractor).
I have replaced all battery cables , goint to replace the batteries today , then probably the ign switch and voltage reg. Repl starter in o4,it should be good. Any help from anyon else would also be appreciated.
ET
04-20-2004 09:30:37
Its called a fuse wire. Its there to provide a chassis ground for the split 12 volt system that runs lights and instruments as well as protect them from 24 volt shorts. If its burned off half of the instuments don't work and one battery does not charge.
