3155 clutch problem
Ben Turzinski
04-19-2004 19:28:32
I have a 3155 mfwd with cab and 5000 hrs. I have had the tractor since new and have had to add fluid to clutch master cylinder a couple of times, light on dash works well. My brother brought the tractor in tonight from spreading potash and said clutch was acting up. He said it pulled fine but would not disengage for shifting. The fluid light was not on. I am not a big fan of these tractors and have had clutches fail on 2940 with less hrs but this hyd. unit is new to me. I plan to try and bleed it out but if anyone would have any advise it would be appreciated. Thanks
david val
04-22-2004 05:51:23
 Re: 3155 clutch problem in reply to Ben Turzinski, 04-19-2004 19:28:32
if it has the inner cylinder (complete with the throw out bearing), look for brake fluid drops at the small hole at the bottom of the clutch housing. if it leaks it needs to be replaced (and at theese hours probably the clutch too) if its with the external cylinder, also look for leakd and for rod travel (3/8 inch).
david
stew
04-20-2004 07:59:44
make sure the adjusting linkage is all tight and propoerly adjusted.. I have a 2955 and one of the check nuts loosened up and the clutch got out of adjustment , it doesn't take much. I have never had to add fluid to my reservoir though
