4230 260 loader electric hydraulic control valve
Bruce
04-19-2004 15:49:47
I have a 4230 w/260 loader. I want to install an electro/hydraulic control valve with an appropriate electronic joystick in the cab for operating the hydraulics. Anyone familiar with any products to do the job?
JDBert
04-20-2004 06:44:59
 Re: 4230 260 loader electric hydraulic control val in reply to Bruce, 04-19-2004 15:49:47
Bruce, are you looking at a electric outlet multiplier? if thats what your looking for they work great only thing you want to do if you get one of these is mount it or make some kinda brace since the added down ward weight of the multiplier will cause a leak at the orginal outlet.
4230
04-20-2004 04:43:58
Your money ahead to buy the parts from deere.
Brokenwrench
04-19-2004 16:56:47
You might be money ahead by installing the Deere joystick hydraulic setup.The valve mounts on the loader frame with quick connects for loader removal and a joystick operated set of cables to the valve.This takes about 2 hours to install,and only has 2 3/8" cables running into the cab.I have bought them used for $500 complete. For you to do what you want you will need a power beyond block under a remote feeding a 2 or 3 spool electomechanical closed center valve with float,plus an electric joystick.Probably the parts alone would be in excess of $1500 plus the necessary wiring and installation.Then you would have to play with flow restrictors so the loader would have some "feel"and not just launch the boom up or down,or dump or curl the bucket in 1 second.Another option if you want a small easy to operate joystick, would be a pilot controlled valve. This uses low pressure oil(possibly charge oil) through the joystick to the valve bank,this setup gives you precise control of the main valve bank,the farther you move the joystick the faster the loader moves. But once again you are in the $1500-2000 range for parts and installation,plus having 6 small hoses running into the cab.
Doug in IL.
04-21-2004 08:58:57
 Re: Re: 4230 260 loader electric hydraulic control in reply to Brokenwrench, 04-19-2004 16:56:47
I have a used one of these units, the complete setup, minus the hoses, if you or anyone else needs one.
Bruce
04-21-2004 12:21:31
 Re: Re: Re: 4230 260 loader electric hydraulic con in reply to Doug in IL., 04-21-2004 08:58:57
Send me an e-mail with list of parts included and your asking price.
