1B Sheller Belt
Tony M
04-19-2004 12:08:08
I have a 1B JD one hole corn sheller I am reworking. It seems I am missing the fan drive belt, and it is no longer available from JD, but shows to be a 3/16" x 37" belt. It looks to me like it will need to be a round or hexagon belt, but I have yet to find anyone who doesn't give me a blank stare when I ask about one. Anyone have any ideas as to what I can use? All help is appreciated.
John
04-20-2004 10:28:10
 Re: 1B Sheller Belt in reply to Tony M, 04-19-2004 12:08:08
Might also try that mscdirect link I referenced for the phase converter.
Mark Scholten
04-20-2004 07:38:08
The sewing machine belt is a good idea and I am going to check into that, however, I found that a 5 gallon paint pail has just about the right length "O" ring in the lid of the bucket. You probably have a couple of gear lube buckets around that you can rob the "O" ring out of and give that a try.
Mark
dan_41jdh
04-19-2004 16:20:45
Tony, a round leather drive belt to fit an old treadle-type sewing machine will work perfectly on that application. They are available from most any sewing machine repair shop, and are usually furnished in one long strip for you to trim to length. A large connecting staple is pre-attached to one end, and you connect the staple to the other end to create the belt you desire. (My wife sells them in her store, and I "requisitioned" one for my sheller.)
