630 dripping oil out vent tube
Robert
04-19-2004 07:56:51
I bought a 630 from a neighbor that he let the head freeze. He had the head off and then didnt fix it. I had the cracks fixed and they did a valve job,put it all back together and runs great, but as soon as it warms up,it starts dripping oil out the vent tube. The dip stick shows it is about half quart low now, 10-30 oil.Any body have an idea what is wrong. Doesnt the oil run back through a passage at the bottom of head like a A? Waiting for some ideas before I pull valve cover back off. Thanks
txblu
04-19-2004 10:23:40
 Re: 630 dripping oil out vent tube in reply to Robert, 04-19-2004 07:56:51
Hang on to your skivvies.
Throw that 10w-30 in the trash! !!!!! !!
Go get some "work" oil, Shell or Chevron or Mobil diesel truck oil 15w-40 and try again. Been there /done that. If that's all that's wrong with it you will quit using oil (for the most part).
Now, if you do have some ring wear and a little combustion pressure winds up in the crankcase, you will vaporize a little oil and it will come out the breather....that's what it's for. The drip is just condensed vaporized oil. You can run a tractor a long time before it's so bad that you need an overhaul. Matter of fact, that is a good indication of your rings....you're level of blowby.
See if that doesn't work for you.
txblu
