7520 motor oil question ???? Clooney?
robert
04-19-2004 03:58:19
Hi all. manual says use 30 weight oil ,says not to use multi viscosity oils.Question, would like to use 15-40 heavy duty oil.Is that OK ,Realize book writen 30 years ago.?? Or do I use 30 ??
robert
04-19-2004 04:04:50
 Re: 7520 motor oil question ???? Clooney? in reply to robert, 04-19-2004 03:58:19
also is JD 303 oil for front diff and rear end and hydraulics etc,now the same oil as say Hyguard Hyd.oil????? ?
G-MAN
04-19-2004 07:43:15
 Re: Re: 7520 motor oil question ???? Clooney? in reply to robert, 04-19-2004 04:04:50
Deere Plus-50 15W-40 is fine to use in your tractor, and is one of the best heavy-duty diesel oils out there, particularly if you'll be operating the tractor during cooler temperatures in the spring and fall. And Deere Hy-Gard replaced the 303 trans/hyd oil. Just make sure you get regular Hy-Gard and not Low Viscosity Hy-Gard, which is made for use with hydrostat systems.
