Edision Mag on a 49 styled D
Randy
04-18-2004 20:10:53
I have a Edision mag on my D and have a very weak spark, Is there anyone out here that can tell me if this is the correct mag and what I can do to check it out. I have new plugs, wire core wires, cleaned points, and the capiactor is not shorted, I do not know enough about this to go farther and would like some assisatnce from you all with some history on this mag. ANY AND ALL HELP WILL BE MUCH APPRECIATED. THANK YOU.
Clooney
04-19-2004 03:17:36
 Re: Edision Mag on a 49 styled D in reply to Randy, 04-18-2004 20:10:53
Randy, what Edison mag are you working with? We need that info to be able to tell you.. If it�s an Edison-Splitdorf CD010 then you "could" have the correct mag for that 49 D [my mag chart is a little iffy for the styled D]..
~As far as spark is concerned again we really need to know the mag type but if you have had it apart, or had the magnet off, of it has been stored for a long time then probably the magnet needs to be recharged [at least to start with].. Other than that see if there is a tag or other markings on it & let us know�
[email protected]
Randy
04-19-2004 06:09:03
 Re: Re: Edision Mag on a 49 styled D in reply to Clooney, 04-19-2004 03:17:36
Clooney,
Thanks for your help, it is the splitdorf and it has been setting in barn for aprx. 10 years. any more help would be appreciated.
Clooney
04-19-2004 18:04:45
 Re: Re: Re: Edision Mag on a 49 styled D in reply to Randy, 04-19-2004 06:09:03
Randy, it's hard to tell what kind of problem [or problems] you will find on that E/S if it's been sitting for 10 years..
~Probably the place to start is to free up & make sure the impulse coupling is free, operating smoothly & is giving a decent snap.. That coupling uses a different type of spring set-up than the Wico's & is prone to rusting & sludging up..
~Next make sure the little brush & brush springs in the outer cap aren't stuck or frozen in their bores [a somewhat common problem].. If those brushes aren't making contact with the rotor you won't get much of a spark..
~While in there, make sure the rotor's brass surface isn't oxidized [another common problem on the E/S]...
~With that mag sitting that long it sure wouldn't hurt to have the horseshoe magnet recharged.. Those magnets do loose their magnetism after a while & if it has ever been pulled apart without a keeper placed across that magnet it probably has lost a lot of it's magnetism.. I usually magnetize the magnet right on the magneto but remove the impulse cup first so the impulse dogs don't also get magnetized..
~Other than that you could have any number of other problems like oxidized points [clean them & re-gap to .015"] ,, or a failed condenser [those are real hard to come by],, or a failed coil..
~If you go into that mag too far remember the drive/driven gear needs to be re-timed at re-assembly..
Look it over & see what you can find.. Then post back or E-Mail with any specific questions...
[email protected]
Randy Losey
04-19-2004 19:46:12
 Re: Re: Re: Re: Edision Mag on a 49 styled D in reply to Clooney , 04-19-2004 18:04:45
Clooney,
Would I be ahead to take this whole mag and either send it off to be rebuilt or get a rebuilt one somewhere?? If so, where would I send it or see about buying one that is already rebuilt.
