37 B steering shaft question
Hal
01-25-2004 17:41:57
I was looking at trying to get some of the slack out of my steering this afternoon, can someone tell me if the bearing behind the worm gear is a taper roller 3 piece bearing? And if so does the inner race for it come off? Mine looks like the inner race part is made with the worm gear and I cant seem to find the outer race. My taper roller part seems way to large for the inner race part that is on the shaft. thanks Hal
John
01-26-2004 11:33:48
 Re: 37 B steering shaft question in reply to Hal, 01-25-2004 17:41:57
I have a 38B. The steering had about 3 turns of slack in it. Took it apart and most of he bearings were gone. Only the races remained. Went to JD they got the bearings (cones) and the races (cups). The tapers on the shaft that the bearings ran on were in sad shape. They still are. I put it back together with the new cups and cones, took a few shims out, and it now only has an inch or so of slack at the outer rim of the steering wheel. If you need the part numbers I will look and see if the boxes are still in the shop.
Clooney
01-26-2004 03:38:07
Hal, to answer your question: The bearing on each end of the worn are 3 piece [well actually 2 piece as the inner bearing races are machined as part of the worm assembly & aren't removable]..
~Those roller rings [the actual row of roller bearings] are quite loose looking when not installed in the bearing.. You need to put the outer races over the rollers while they are on the worm to see if the fit is correct..
~Look closely for pitting, brinelling, or the rollers being egg shaped.. Before getting too involved in pulling the outer races make sure you can still get them from Deere. I don�t know about the early B but most of those early steering bearings aren�t still serviced by Deere & those bearings don�t seem to match up to replacements from the bearing houses.. [I guess what I�m saying is don�t wreck those bearings until you are sure you can get replacements]... If you can get new replacement outer races you can simply run a few small beads of weld inside the old bearing races & they will pull right out after the weld cools & shrinks the races slightly, then use the old removed races [flipped over] to drive the new ones in.
~While you have it apart remove the sector gear & the top vertical shaft eccentric bushing & check it�s center for wear.. Those bushing center bores wear egg shaped & that won�t allow a proper sector to worm adjustment to take the play out of the worm to sector gear.. I don�t know if that bushing is still available from Deere [I have my doubts] so you might need to machine the center back round & install a thin wall bushing to repair that [remember that bushing must be eccentric between it�s OD & ID so don�t center that thin wall bushing..
~I won�t go through the adjustment procedure as it sounds like you have tried that & are now working on a wear problem..
[email protected]
John T
01-25-2004 20:08:15
Hal, its been a while since I was into my 38 B to tighten up the excess steering wheel rotational slack, but it had a cone with rollers bearing out there on the end if I recall correctly. When I bought a new bearing and cup/race we had to use a special punch we made with a ground out hollow space to punch out the old cup/race. It was a tricky job.
1) The first thing you might try if the steering shaft has excess fore and aft horizontal end play, is to remove the end bearing race cap (2 bolts out on top end) and see if it has numerous shim gaskets that can be partly removed to take up the horizontal end play. They purposely were made with more than 1 gasket/shim under that bearing end cap, so removal of some would put more pre load on the bearing to take up excess horizontal slack.
2) If that dont do the trick, if the eccentric bushing isnt totally worn out, you remove the 4 top screws on top the pedestal, clean out the grease, remove the vertical set screw from one of the semi round cut out stops in the base of the eccentric bushing, then rotate the eccentric bushing to move the sector grear closer over against the worm. CAUTION most wear is in the straight ahead middle postition, so DO NOT have the sector too close to the worm there such that it binds out near the turn ends. Jacking up the front slightly as you adjust allows for a good end to end feel.
3) If the eccentric bushing is worn and/or wollowed out, you may not be able to take up the needed slack.
Parts Catalog PC676 for Unstyled B shows:
PN JD 7364R Cone, with rollers
PN JD 8212R Cup
Post back any questions or e mail [email protected]
Good Luck n God Bless
John T
