Clutch disk removal on JD B
Charlie
04-17-2004 16:11:43
Does anyone know where to get, or how to make a puller that can be used to remove the clutch disk on a late model B? I have went to all the tool stores and rental places and nothing seems to work. The studs that are screwed in too the clutch disk as anchors are to big for the pullers I have found.
Kris A NC
04-18-2004 19:44:20
 Re: Clutch disk removal on JD B in reply to Charlie, 04-17-2004 16:11:43
I just did the clutch work on my '51 B and I was able to use a three claw puller. Came off with a little PB blaster and some heat. No problem. Took me about 20 min. My .02
Kris A NC
RayP(MI)
04-17-2004 18:33:44
If it's like mine, there are two threaded holes in the disk. Get bolts that fit them. Place a deep socket of appropriate size (large as you can fit in center hole) against the end of crankshaft. Place a heavy piece of strap iron across the other end of socket. Bolts go through two holes drilled in strap, and into holes in clutch plate. As you tighten the bolts alternately, clutch plate should come loose, and pull out. What you've made is a custom puller for that application!
havvey
04-17-2004 17:41:19
sir if it takes just 2 bolts build an over center puller out of 1/2 inch square stock and a 5/8 nut we did this for a late b you could turn the bolt shafts down to fit the puller also
