2010RU Oil Pump/Distributor timing. HELP
Britt
04-17-2004 15:01:10
I am installing the oil pump on a short block for a 2010RU. The service manual calls out a special timing tool (AM450T) to time the oil pump to the camshaft. Of course I don't have one. It has a Prestolite distributor. The distributor is driven by an offset tang that mates with the top of the oil pump shaft.
If some one could tell me which way the distributor rotor points with the #1 cylinder at TDC on the compression stroke, I could time it without the tool. I suppose that I could just slap it in and wire the cap accordingly, but I would rather do it correctly. Does anybody have a quick way to time the oil pump without the tool?
Thanks,
Britt
