Bolts on the exhaust manifold of late JD A
Charlie
04-17-2004 08:17:19
While trying to remove the muffler, I just found out that I have a rust hole in my exhaust manifold. The bolts look really rusty and seem frozen solid. Is there a secret to removing these without breaking them off? If I run the tractor first until the manifold heats up and then try, will that make it easier?
JC
04-17-2004 10:05:31
 Re: Bolts on the exhaust manifold of late JD A in reply to Charlie, 04-17-2004 08:17:19
We use a penetrating oil here called "Break-away" which works really well. Not sure if it is available in the USA.
As to removing the studs {or broken bolts}, a friend of mine is a master at it. He tries penetrating oil first, then taps them hard with a ball peen hammar to break the rust bond, then he works them back and forth with vise grips if he can get a grip. Heating them up with the torch always helps.
Finally, if they break off flush and there isn't enough to grab onto, we drill a hole in the centre of the stud or bolt and carefully "blow" it out with the cutting torch. The torch burns away the stud or bolt material but doesn't seem to erode the cast iron - not sure why. Lastly, we use a tap to clean up the tapped hole.
John T
04-17-2004 09:36:00
If theres any "secret" to removing those rusted/frozen nuts or bolts, I sure aint found it. I usually have to cut them off at the heads base under the manifold (to remove manifold) then drill out and re tap, but here's how I approach the subject. I try to unscrew them first, of course, but if that fails, youre probably gonna end up drilling them out and tapping. Running the tractor for a warm up "might" make thins easier to answer your question.
1) If its actually "nuts" on top of studs, I firt try to heat them cherry red (try n heat the outer nut, NOT the stud itself as much as possible, let cool then try), then use a proper sized or undersized SAE or Metric 6 point socket to get a good sure solid bite, then use a wrench and shock/hammer/hit the wrenches end versus any hard dead pull, and often the nuts will turn off leaving the studs in place.
2) If you get all the nuts off, I then try n soak the manifold top and stud area with PB Blaster or other penetrants to try n penetrate down the manifold and stud openings/holes. (manifolds often corrode to the studs badly, so it wont raise or release its death grip)
3) If you can raise the manifold, you may have to resort to sawing off the studs near the top of the head so you can get the manifold removed. (studs corrode to manifols usually is the problem)
4) Next, I might try a stud remover or pipe wrench etc etc etc if I can get any bite on the studs tops then again use shocking hammer blows n vibrations on the wrenches end to try n turn them out.
5) If that fails, weld a washer to the top of the stud, then weld a nut to the washer, then see if you can shock/hammer them out with a wrench on the welded nut.
6) If that fails, grind the stud tops smooth n even, use a center punch to mark the dead center, then drill them out starting with a small, then progressibely larger bits, or even left hand bits if you have any. DO NOT DRILL TOO DEEP you may get down into the pushrod tubes on some heads. Use a depth stopper on the drill.
If the head to manifold surface isnt smooth n flat (often pitted/burned out), I have them planed/milled at a machine shop and the manifold likewise if its a used one. If its not bad and you dont wanna remove the head, dress it flat n even as possible with a file or other tool. Install a new gasket and new studs n nuts and youre good to go. I use high temp anti sieze up on top on the nuts and coat the stud tops with it, but I want the studs to stay tight into the heads, be sure n get the right kind of new studs for a good tight seal which wont unscrew if you unscrew the top nuts in the future. Once all waremd up a few times, I re torque the top nuts.
Good luck n God Bless, if theres any secrets lol maybe others can post them, but heat n shocking blows and then drill n tap are how I usually have to do it.
John T in Indiana
