Charlie, to replace the muffler: a) You gotta remove the hood; b) To do that you gotta remove the steerign shaft; c) To do that you gotta first remove the big nut then steering wheel (may require heat and a puller) its keyed on a shaft and comes off toward the driver; d) Then you gotta remove the entire steerign shaft (worm stays on its front) forward out front of tractor by first removing the tractors front/top sheet metal, then remove the two horizontal end bearing cap bolts on front of steerign shaft housing on top front of tractor/pedestal; remove end bearign cap assembly, remove the packign nut on other end of steering shaft; e) Then you remove the 4 top screws on top the steerign pedestal and remove the big top nut on top the vertical steerign shaft to free the sector gear. (Seems like on "some" tractors that could remain in place while the worm gear unscrewed forward and the whole shaft came out forward with sector gear still in place, but its been a while) f) Then the whole long steering shaft unsecrews and pulls out forward alllll ll the way out the front with its worm gear intact. Thats the reason many hoods have been butchered with the big square sheet metal patch around muffler pass through area on top to remove and replace the muffler WITHOUT having to remove the hood and steerign shaft per the above. If you have any excess steerign wheel play, thats the perfect time to adjust those end bearign cap shim/gaskets and the eccentric bushing if the sector gear needs moved closer over against the worm. I coat the new bolts with anti sieze lube when I replace things in the muffler area. Post back or e mail [email protected] any questions, maybe theres other ways, but this is how Ive done it, let us know. Good luck n God Bless ya John T
