4020 D, early Model, basketcase, lots of blowby
Adam
04-17-2004 07:22:30
Hedgerow tractor. Much rust in cooling system. Block still had some green water in block when we removed drain cock on left side of block. Engine was not stuck. Rebuilt injection pump, got it started last night. Had MW turbo. Turbo oil return hose, plumbed to vapor pump on leftside of engine, not yet plugged.
Problem: Massive blow by.
Cause: Cracked/rusted sleeve, problem with vapor pump, dry valve seals?
We are going to fill the cooling system today and see where the water goes.
ABW
