1938 A question
TS
04-17-2004 04:29:36
Got the head off my `38 A,gasket set ordered. Does water circulate into the main case from the cylinders?? Just didn't know if I should go ahead and pull the cylinders and change that gasket while I had it apart. Had a water leak into oil.
Thanks,
TS
havvey
04-17-2004 14:46:19
 Re: 1938 A question in reply to TS, 04-17-2004 04:29:36
no the gasket under the block is for oil there is brass tubes in the head that can leak water they are in some pushrod tubes check for cracks also
