3020 pto brake
mikeinWA
04-16-2004 23:03:17
I have been chasing down a problem with pto, and my manual does not seem to explain the operation of the pto brake. I have the JD shop manual. Can someone shed some light on the subject for me or point out the location of this info in the manual?
Brokenwrench
04-17-2004 03:59:24
 Re: 3020 pto brake in reply to mikeinWA, 04-16-2004 23:03:17
The pto brake is designed to stop and hold the pto only from turning by applying a matchpack sized brake pad to the gear train. Early models uses a mechanical linkage to do this.As you pulled the pto lever back,it would disengage the clutch,and then as the lever was pulled back farther,the yoke would contact a rod and push it back applying the brake.The console and powershift models used hydraulic pressure to do this.As the lever was pulled back it disengaged the clutch,and when pulled all the way back,it applies oil pressure to the pto brake circuit. If your shaft is still turning,the clutches check ok and the linkage is adjusted correctly,you probably need to replace the pto brake. Like I said it's the size of a match pack,and it only takes a couple of times trying to stop a rotary mower,feed grinder,or baler to effectively render it useless.It's made to hold the pto only,not to stop an implement.If you have a powershift tractor and the pto clutches become warped,this is usually enough drag to override the brake. To replace it,the tractor must be split between the rear end and transmission.
mikeinWA
04-17-2004 07:15:19
 Re: Re: 3020 pto brake in reply to Brokenwrench, 04-17-2004 03:59:24
riverbend- thanks a ton for all the info. The problem I posted earlier (pto wont disengage) is intermittent. In the process of adjusting the linkage I only broke one rod, of course it is the rod running down through clutch housing behind dash. My tractor is a '68 3020 diesel synchro. I have yet to conclusively ID the pto problem, but without the linkage connected it does not turn. I fear the brake may not have been working when I purchased tractor. It was used almost exclusively as a feed tractor on a dairy operation and now it is used as a plow and disk rig on our vegetable farm. The systems the previous owner used and the ones I use now arte different so I have had to tune and adjust and unstick all the operations we need and the dairy did not (draft control etc.) I knew I was operating on borrowed time regarding the clutches, but I really do not look forward to splitting the tractor in two places. Live and learn right? It would be helpful to see a diagram of the workings of the pto brake, any suggestions? I have the JD manual but it only touches on the subject in the clutch section. Thanks again for your help.
