Clutch lever movement
donwisc
04-16-2004 18:35:42
Most 2 cylinder JDs clutch levers have a lot of slop due to wear of the bolt or bushing. I just replaced the bushing in my US model A and while it improved the situation it didnt cure it.
The side to side movement is determined by the shoulder bolt butting up against the lug on the gear case.
For the heck of it I put a 3/4 inche washer in between the clutch lever and the lug so now you can adjust the clearance and movement of the lever. This took care of all excess slop and operates like new. This could save buying the expensive repacement shoulder bolt.
Scott Old44B
04-17-2004 19:04:38
 Re: Clutch lever movement in reply to donwisc, 04-16-2004 18:35:42
Why do so many of you guy's think that it's so terrible to go to a Deere dealer and get a part that is still in production for a tractor that's 50 or 60 years old. I'm just darn glad that I can still get the NEW part, makes restoring a Deere tractor pretty nice.
donwisc
04-17-2004 20:02:26
 Re: Re: Clutch lever movement in reply to Scott Old44B, 04-17-2004 19:04:38
Hey Scott Im not running down Deere, this was just an alternative. The money saved here usually goes to other parts. The dealer in Burlington carries an unusual amount of 2 cyl parts and had a carb cover and screen for my 38 A IN STOCK.
Thats why I prefer to restore the old Deeres.
JC
04-17-2004 10:25:41
I changed the bushing in the lever and the special shoulder bolt on my "D". Pretty 'stabby' price for the shoulder bolt and bushing from Deere.
In some cases I've found that by the time I pay for a generic part and pay someone to machine it to size, it's often as cheap in the long run, {and original} to buy the right part.
I agree with you that there are many ways to fix problems on these 'old girls'.
mitch
04-16-2004 19:06:39
sure is nice to have all that slop gone, just went through mine and man what a difference
