720 with power steering problems
Russ
04-16-2004 16:10:47
I have a 1957 JD 720 with power steering, the steering locks up, more to the left than the right. All the gears look like new, I had it appart and will work good for a short time then will act up. Any help. Thank's Russ
Hilltopper
04-17-2004 19:43:17
 Re: 720 with power steering problems in reply to Russ, 04-16-2004 16:10:47
I have a 70 that does that. It never gave any trouble until I took the end play out of the worm shaft. Then it started binding when it got hot. I just worked on mine again. I decided the worm shaft is to tight against the gear. It had a .016 gasket in there. I made one out of .027 gasket material. I am going to try it. Havent used it much since. This make 4 times I have had it apart. The vertical shaft may have a slight bend in it causing it to bind. The book says to measure the free play on the outer edge of the steering wheel. Measure it turned left, center and right. see if there is a difference. I found some difference in mine. Hope this helps. I could find nothing wrong internally on mine.
