GM Left Main AF1284?
DPOST
04-16-2004 08:20:52
Hi;
Gee I found one of the thrust flanges in the sump of my 45GM. The tractor haddn't s run for about 10 years and I am finally getting around to trying to get it running again.
The end play was excessie like 1/2 in which probably caused the problem. The crank splines look ok but I haven't measured them yet. The bearing on the crank looks good except for some rust stains. The catch is the crank shaft is 2.984 diameter instead of 2.999. We had rebuilt the engine in the early 60's and I remember that we took the crank in and had rods rebbbited, It appears that we also had the mains undersized.
Anyway the question is where can I get a .015 undersize AF1284?
Thanks in advance
D.D.Post
Mike M
04-16-2004 12:57:23
 Re: GM Left Main AF1284? in reply to DPOST, 04-16-2004 08:20:52
You say it looks good except for rust stains. I think I would polish it with some fine wet or dry paper in the parts washer or some synthetic steel wool then check it out better.
