420 in the weeds--Is it worth saving?
Kevin (FL)
04-16-2004 07:00:18
I haven't heard back from anyone on my earlier post so I'm reposting:
I originally asked about a 720 but was mistaken--this is a 420, not a 720.
As I said I have no knowledge of the green tractors other than a basic idea of the various model #'s over the years. This one has a square front axle, wide front end, 3-point hitch. Sheet metal looks to be all there--rusty but fair-to-good condition as far as dents. Both front lights are there, but they look a little rough. Don't know if it has power steering or not. Tires are shot, rims are questionable but may be OK. Tractor has been sitting several years.
I'm asking about what its worth as it sits. I have to assume the engine isn't cracked open or anything. Thanks for any advice.
Johnnyputt
04-17-2004 08:02:53
 Re: 420 in the weeds--Is it worth saving? in reply to Kevin (FL), 04-16-2004 07:00:18
First thing I'd do is fine out what model of a 420 it is. They have several different, and it'll be on the serial number tag. Any of the first four listed below aren't considered rare unless they are all fuel or LP. Options, like power steering, float ride seat, direction reverser, etc., will make each worth more. The last two are considered to be rare and are worth lots more, especially the V.
U - utility
S - standard
T - Tricycle
W - wide
H - highcrop
V - Semi-highcrop
BMeyer
ChuckW
04-16-2004 13:23:59
probably a lot of people have been onto the tractor your viewing but I tell you from 100% experience it is cheaper to buy a tractor than to fix up a tractor like this. Now if your goal is simply to restore and monetary consideration is second you may want to tackle.
PeteNY
04-16-2004 07:21:46
Here in NY $750 as a parts tractor will make ya some money...but it'll get expensive to fix it so I'd stay in the $600 or under range if that's your plan.
old
04-16-2004 07:09:45
Picked up a farmall 450 a month or so ago for $350. I'd say any where from $100-700 depending on if engine is stuck but start low you can always go higher
Kevin (FL)
04-16-2004 10:57:39
 Re: Re: 420 in the weeds--Is it worth saving? in reply to old, 04-16-2004 07:09:45
Thanks guys for the feedback. In other words there "ain't nuttin special" about the 420. Now if it were a 330 I figure you guys would be asking where it was or something...I've heard that one goes for pretty high money in any condition....
buickanddeere
04-16-2004 12:54:11
 Re: Re: Re: 420 in the weeds--Is it worth saving? in reply to Kevin (FL), 04-16-2004 10:57:39
Can't hurt to check it over and run the the serial number on the long shot it has a custom job number. Anything like dual rockshafts, remote hydraulic outlets, power steering, float ride seat, swept back front axle, high altitude engine could make her an above average clunker. Not too many with 34" rear tires if a "w" chassis. There even were parts one time to convert some tractors to 1000rpm, rare indeed to find a conversion.
