1010 motor change over
chris
04-15-2004 20:07:57
we have been changing a motor from a john deere 45 combine to a 1010 we have just about got ever thing done when we relize that the manifold come out right unde rthe gas tank and my old intake is no good off the other motor plus dont want to use the small one any way does anyone have any ideal if you could find a diffrent tank to fit it i needs to be littler than the one i have mine evan has a hole through it for the steering rod does anyone have any ideas thanks so much chris
Brokenwrench
04-16-2004 13:35:42
 Re: 1010 motor change over in reply to chris, 04-15-2004 20:07:57
I'm afraid you will have to replace the manifold with the correct one. The 1010's have the steering shaft running through the fuel tank and there is no way of adapting around that,unless you want to run a 2 gallon lawn mower tank rigged under the hood. Those manifolds should be plentiful in salvage yards,or a new repro manifold should only be $120.
