Friends MT very loose steering, HELP
Ben.So.Tex
04-15-2004 18:42:10
Does the steering on a MT have a coupler in the upright steering housing? He can turn the steering wheel almost a full round before the wheels move, the worm gear is got some wear in it also (we had the inspection plate off). What might be the problem? Thanks Ben
chooch
04-19-2004 07:10:24
 Re: Friends MT very loose steering, HELP in reply to Ben.So.Tex, 04-15-2004 18:42:10
Ben.So.Tex
There is a coupler located on the bottom of the steering shaft where the upright steering column bolts on to the lower pedistal. To get to it, you have to remove the steering shaft, steering box, and upper steering column. The coupler should be visible at this point.
Assuming you have no more adjustment on the set screw on top of the steering box, part of your problem could also lie in the steering box. There are two dowels that project down into the worm gear. These are notorious for causing loose steering on these tractors. Over years of use, the dowels are worn flat on the sides that come into contact with the worm gear. Similarly, the worm gear gets worn where the dowels come into contact with it. This usually noticable by having loose steering while going straight or making slight turns (middle of the worm gear) and tighter steering while making hard turns (ends of the worm gear). The dowels are still available from Ma deere or you can grind off the top, drive them out, rotate 90 degrees and put them back in so that the flatten part of the dowel no longer is riding against the worm gear. Hope this helps.
