Drive disk
Woody
04-15-2004 17:49:30
What dose it take to remove the clutch drive disk on a John deere "B" the bolt is out but one of the holes has a broken bolt in it can it be removed with only one bolt driven in do I need to heat it before driving the bolt in... Thanks CjW
Ralph - Wi
04-15-2004 18:28:41
 Re: Drive disk in reply to Woody, 04-15-2004 17:49:30
Since one bolt is broken, I am assuming that it was broken because it is really tight!!. I am in the midst of that process right now. I forgot to dump a dose of oil in the first reduction gear (long dash A). To make a long story shorter, it will bind with only one bolt!!. If it were mine I would drill the center out to weaken it. Then get two bolts and start anew. I swiped the two 1/2" nut at the base of the fan support and replaced them with hex nuts. Now I need to hide them where I can find them the next time they are needed.
