Mike: Short answer...Yes. Now, for some detail. There is a voltage threshold where the electrical potential exceeds the galvanic skin resistance of the human body....that means there is a point where the voltage gets high enough to penetrate to the deep tissue and electrocution begins. 36 volts is right around that threshold. Now I know there will be a lot of people saying it's really more like 50 volts, but in electrolysis, you 'll be handling these wires in a salt-water dampened state. I'm just saying that if you had a power supply with a half wave recitfier, pumping 4 or 5 amps at 90 volts, and you were fiddling around with salt water and that voltage.....you run a real risk of shock AND MAYBE DEATH! At least the family pet should be kept out of the area along with any kids you want to grow up. Again, the higher the voltage, the faster it goes, but also the higher the temp, the faster it goes. I currently use a 5 volt computer power supply that runs at a very high current (up to 400 amps), and it does a fine job all the time. At 36 volts you probably don't have a problem, but it really depends how safe you keep your tank and your workspace. I like lower voltages as it leaves a lot more room for folks to make sparks but not kill each other. I hope this answers your question. Frank
