3020 synchro pto wont disengage
mikeinWA
04-15-2004 14:20:25
Noticed some drag on pto yesterday with spreader attached, pto would disengage if I revved the engine. Today pto continues to move and pto brake doesnt operate. I am currently checking out the linkage, and the cam under the dash seems pretty worn. This may have caused tractor to be operated with pto lever partially engaging brake for some time. Are there any diognostics I can perform to ID the problem before splitting the tractor?
Brokenwrench
04-15-2004 16:16:56
 Re: 3020 synchro pto wont disengage in reply to mikeinWA, 04-15-2004 14:20:25
If it is not the linkage,and a look through the bottom doesn't show a problem like a broken finger,or backed out set bolt or bad throw out bearing,I would venture a guess that the pto disc has come apart and is wedging itself engaged. This will entail splitting the tractor. Probably not what you wanted to hear.
mikeinWA
04-15-2004 17:23:45
 Re: Re: 3020 synchro pto wont disengage in reply to Brokenwrench, 04-15-2004 16:16:56
everything underneath looks skookum. The lever shows about 2 inches of play 5" from center of shaft, manual calls for one and I am presently practicing some serious yoga type stretching and bending to get my fat a$$ wedged in between the floor boards and brake pedals to free the stuck adjuster. Gots ta disk fellas!!!! Good thing the weather turned here or I would really be climbing the walls. One more question; manual lists pto brake rod, a mushroom shaped stop at bottom of tractor against which release fork assembly rests when lever is pulled back. Is this supposed to move? or is it just a stop? Thanks for the help everyone.
Brokenwrench
04-16-2004 04:21:54
 Re: Re: Re: 3020 synchro pto wont disengage in reply to mikeinWA, 04-15-2004 17:23:45
That brake rod should move. As the lever is pulled back it should contact the brake rod and push it back to engage the pto brake.
G-MAN
04-15-2004 15:41:02
Drop the cover off the bottom of the clutch housing and get under the tractor and observe what happens in the clutch area while someone else operates the lever. The clutch is a two-section design. Half is for the traction clutch and half for the PTO clutch.
