420 W
Nat
04-15-2004 11:44:49
I just biught a 420 W with a 35 loader on it. It runs and starts great, but the 3ph will only come halfway up. It is full of fluid, and the loader will go all the way to the top, but isn't smooth. If you lift the 3ph and let it come to the 1/2 way position, the loader won't go up, but if you lower the 3ph and hold the up valve on the loader it will jump up. I have heard that the draft controll could be sticking and cause it to do wierd things, anyone have any ideas? Thanks , Nat
buickanddeere
04-15-2004 20:06:02
 Re: 420 W in reply to Nat, 04-15-2004 11:44:49
Is the loader equiped for down pressure? If not she's running out of oil without an external storage tank.
Ray
04-15-2004 18:28:10
It's probably starving for oil,the 420 hydraulic
system wasn't made for a loader.I've seen
several with an extra hydraulic tank to give
it enough fluid to raise a loader.
Nat
04-15-2004 19:25:47
 Re: Re: 420 W in reply to Ray, 04-15-2004 18:28:10
I don't know if that is the problem, if you let the loader all the way down it still won't raise the 3ph. It seems to raise fine till it gets about 1/2 way and then acts as if there is to much weight on it and just stalls, almost as if something was holding it down. Thanks, Nat
Ray
04-16-2004 18:50:28
 Re: Re: Re: 420 W in reply to Nat, 04-15-2004 19:25:47
There could be air in the system if it's
starving for oil.This would only let the 3pt
raise part way,then get air instead of oil
and stop moving.The leather seals in the
rockshaft unit could also be bad and let it
bypass oil.You could have two different
problems.
