2020 diesel
James
04-15-2004 11:26:17
The pump needs re-building, if I take it off, can someone guide me through the process of putting it on and making sure it is in time. Thankx.
Brokenwrench
04-15-2004 16:02:30
 Re: 2020 diesel in reply to James, 04-15-2004 11:26:17
The easiest way to do it is align the timing marks on the pump before you remove it. There is a small rectangular plate on the side of the pump held on with 2 screws. Shut off the fuel at the tank,remove the cover on the injection pump(have a small bucket because some fuel will run out)Turn the engine over slowly until the the marks line up. There is a fixed mark on the pump,and as you turn the engine over the other mark will come around. Once you have the marks lined up,disconnect the battery so no-one tries to turn the tractor over. Remove the lines,and unbolt the pump and slide it off the shaft. When you reinstall the pump,line up the timing marks,you will need the tool to collapse the seals as you slide the pump over the shaft.Be carefull to not cut or roll the seals,or you will end up with a crankcase full of fuel.The pump shop might loan the tool to you. Its not a bad job,just be carefull and make sure everything is kept clean,and replace the fuel filter before starting the tractor.Any other questions post back.
