4010 with a knock
jack
04-15-2004 06:42:20
Hi bought a 4010 motor for my tractor and it was suppose to have the bottom end rebuilt.Well when we fired it up on a stand before installing it had a knock in it.About 1/2 way up on motor.coming from the 2 center pistons.Loosing the injector line on them did make it a lil more quite.But still knocks.Can it be that it is not timed right or can it be that it has a 4020 pump on it and is overfueling?We found the oil pump wasn't installed right and had to put it right.Can this be a timing knock? Didn't have anyway to get it correct.Till we can get it into the frame and aline the marks on clutch housing.But we are very close..HAd to turn pump a little to make it smooth out and run right.I think it is piston slap or a wristpin but no way of telling.Can it be carbon knock?We are going to put in frame and let it run for a while and hope it gets better.Any and all help would be great....I'm not much of a mechanic and really need it going.Thanks .....Jack
Bob
04-15-2004 07:07:05
 Re: 4010 with a knock in reply to jack, 04-15-2004 06:42:20
Nobody likes to spend money, but in your case, you'd be ahead to get a knowledgeable diesel mechanic to take a look at your tractor. If it has a mechanical problem (rod bearing, wrist pin, piston, etc.), and it comes apart while you continue to run it, you're out $THOUSANDS$.
It's not a Briggs and Stratton your messing with here!
What you could do, though, is get it to where you can check the timing, and get the part # off the pump to be sure what pump you have. Generally, the 4010 pump has two SEPARATE levers on the fuel injection pump. One hooks to the throttle, and the other hooks to a cable to the "KILL" knob.
A 4020 pump has only one lever that is hooked to the throttle, and stopping the engine is accomplished by pulling the override knob on the throttle lever, so it can go below slow idle and stop the engine.
You mention the knock changes when you loosen certain injector line(s). An injector stuck open, or with low crack pressure will cause that cylinder to knock, or the knock could be from piston, wrist pin, or rod bearing, and taking the fuel away from that cylinder will lessen the knock.
Whatever you do, if the timing and injectors check out, don't continue to run it until you "ventilate" your block!
