Help identify generator
Randy G.
04-14-2004 21:20:47
I have a generator I believe to be the one I replaced 21 yrs ago with an alternator but not sure its the same one. Its a Delco-Remy, model #949u or it may be a J, sn #281212. It originaly came of a JD 1949 6 volt tractor. Please help me if you can identify the one I have. Thanks!
Randy G.
Clooney
04-15-2004 03:01:13
 Re: Help identify generator in reply to Randy G., 04-14-2004 21:20:47
Randy, I don't show any of those numbers either in my Delco tractor info or auto info..
~See if there are any other stamped numbers on the generator frame & if so post them here.. The numbers will probably look something like 110XXXX or 111XXXX with X being a digit..
[email protected]
Duane Larson
04-14-2004 21:38:05
Randy,
DR generators normally have a number like 1100506, 1100508, 1100588, or 1101356, which are all 6V generators used on A, B, and D tractors. Your number looks like it is associated with a rebuild shop, where they replaced the original tag. The original DR serial number is a combination of numbers and letters, which is a date code.
Maybe someone knows how to interpret your tag - I sure will be interested if they do!
