B power trol and hydraulics operation
Daniel Chestnut
04-14-2004 18:33:36
I currently have an Yakima ABG-2000 hitch on my B. I'm wanting to pull a JD CC cultivator or a #8 sickle bar mower with it, but I'm afraid the hitch will come down and hit the implements. Is there any way I can use the hydraulics without the hitch going up and down? Thanks in advance.
Clooney
04-15-2004 03:31:53
 Re: B power trol and hydraulics operation in reply to Daniel Chestnut, 04-14-2004 18:33:36
Daniel, Yes.. You will either need to plumb the remote cylinder out the rear Power-Trol ports using closed front adapters in the rear of the P/T ports [I presume you are using Pioneer fittings on the side ports now].. Or use a selector valve in the lower rear P/T port to close off the oil pressure to the on board hitch... Or use what you have now & raise the tractor hitch to the top then back the metering valve out to hold the hitch in the raised position.. Or make a bolt in bar that will hold the hitch where you need it to be out of the way.. [lots of options]..
[email protected]
