Dist cap for D-R on 52 A
Mike in AR
04-14-2004 18:30:26
Who has got distributor caps for the Delco-Remys found on a 52A? Mine has the 3 vertical poles and I cant find one around here- even the local JD dealer only can get the one with the 90 deg poles.
Earl S.
04-16-2004 14:36:23
 Re: Dist cap for D-R on 52 A in reply to Mike in AR , 04-14-2004 18:30:26
What is the Delco Dist. Number?
Mike in AR
04-17-2004 16:24:28
 Re: Re: Dist cap for D-R on 52 A in reply to Earl S., 04-16-2004 14:36:23
Earl The number on the distributor is 1111558 5 J26.
The word "model" is directly under the four ones.
Thanks.
Gpower
04-15-2004 06:33:16
Sounds like someone used one off a different application. The correct one foe your distributer is the one your dealer has. It will still work, may have to rotate the housing back to the right spot to line it up properly so that the points open at the right time. It can be done.
good luck
