3020 pto brake not working
Rusty Gordon
04-14-2004 15:58:52
I have a 1966 3020 with a powershift and the pto does not disengage when the lever is pulled back. If a heavy load is placed on it, it will stop but is aggravating because of having to shut off the tractor to hook up a mower. I have checked the lever adjustment and according to my john deere service manual I should install a pressure gauge in the hole in the valve housing marked "BR" and check for 150psi. The problem is my valve housing does not have a "BR" plug, it only has the plug refered to as "CL" . If I put the gauge in this hole and check for pressure when I pull the lever back should there be no pressure? Will this tell me if this is my problem? Any help greatly appreciated.
G-MAN
04-14-2004 16:18:39
 Re: 3020 pto brake not working in reply to Rusty Gordon, 04-14-2004 15:58:52
The "CL" is for "clutch", and yes, that port should have no pressure with the PTO disengaged. What happens is that the pressures basically flip-flop. Brake pressure is applied when clutch pressure is released and vice-versa. The fact that it takes a fairly heavy load to stop the PTO shaft leads me to believe that either you're retaining some pressure in the clutch with the PTO engaged, or that you have warped PTO clutch disks, and they're dragging all the time. Or, you could have a leak in the PTO brake circuit that's not allowing full application of the brake. Yet another possibility is that all the friction material is gone off the brake assembly, OR the pin that stops the brake from rotating in it's bore is broken off, allowing the brake to spin with the PTO gear that it reacts against to stop. I know you mentioned adjusting the linkage, but make doubly sure that the lower arm is tight on it's shaft - the one that goes through the casting and into the valve assembly. If it's loose and not moving the valve fully, it can cause problems. The most recent one I dealt with was on a 4020 powershift. The local C-IH dealer sold it to a guy, and it took out the PTO clutch right away. They replaced the clutch but failed to recheck the pressure to verify that it was within spec and consistent. He brought it to us to double-check, and I found the lever loose on the valve shaft, so it was only a matter of time before it would have ruined the clutch again. That sealed the deal with the Binder boys - they got their tractor back and he got his money back.
Rusty Gordon
04-15-2004 17:54:05
 Re: Re: 3020 pto brake not working in reply to G-MAN, 04-14-2004 16:18:39
I checked the pressure in the port marked "CL" and with the pto lever pulled back it has no pressure at all. I assume this means the problem is either pto brake or warped clutch disks. When the tractor is off I can turn the pto shaft by hand easily. Does this mean clutch disks are not warped? Also pto does not slip when engaged under a heavy load.
Bob
04-14-2004 16:09:27
The problem is often heat warped plates, or worn splines that hang up the discs and cause drag.
Even with a PTO that doesn't try to run all the time the tractor is running, it is still good safety practice to shut off the tractor before doing ANYTHING around the PTO. I always do.
Greg Andrew
01-03-2007 18:46:06
 Re: Re: 3020 pto brake not working in reply to Bob, 04-14-2004 16:09:27
Was there a follow up to this problem?
I have the same problem and it is driving me crazy. I have removed the PTO clutch pack and checked the discs. They are flat and not worn at all. Everything is very clean. Pressures are all in specification. The PTO piston engages while testing with about 80 PSI air pressure and disengages immediately.
When the engine is running, the PTO is running. It takes a real load to stop it from spinning. By real load I mean that I can bush hog and bale hay without turning the PTO on.
I have ordered a new PTO brake but I believe it will wear out very quickly after installation and use unless I can find a solution.
(John Deere 3020, power shift, 1966)
