How many plows for 720 Diesel
RedandGreen
04-14-2004 14:55:09
Am wondering how many plows can it pull and in what gear?, Would love to hear some of your plowing story's using two cylinder JD tractors gas and diesel.
JD
04-16-2004 10:04:19
 Re: How many plows for 720 Diesel in reply to RedandGreen, 04-14-2004 14:55:09
third party image
Here is a plowing photo. 2 bottom on a 70 gas, 2nd gear at best. Almost didnt make it up th elittle hill at the end, but I didnt have it adjusted quite right. I think I can make it better. This was old sod on clay.
Craig M.
04-16-2004 08:52:20
I have a 720D in 2002 I plowed some with it. The ground was in sod (and the old timers said that it has been in sod for 30+ years that he knows of, I have had the land for only 4 years) I was pulling a 3-16 two way at about 8 to 10 in. deep. I was in 2nd. gear all the time and a lot of the time the frount tires were held about 10 to 12 in off the ground for up to 200 to 300 feet at time.
In 2003 i plowed the same groung and I was able to go in 3rd. gear. Most of the sod was ded. but the areas that were not I was back in 2nd to get through these areas
Hillbilly in Vegas
04-15-2004 18:25:21
My brother participated in a "first annual two-cylinder plow day" back in East Tennessee last weekend. He plowed with my 620 gas pulling 2-14". The 620 pulls them easily in 4th gear and is fairly fuel efficient. One of our friends was pulling 3-16" behind his 630 in 3rd gear and 3-18" behind his 730D in 4th gear. But as 720Deere said, the soil makes a huge difference, as well as how deep you plow, lay of the land, and added ballast. I have two 730 Diesels but haven't bought any plows for them yet. The 730 owner's manual gives the capacity for work at 5-14". Again, subject to your plowing conditions. Our friend is planning to get 4-16" for his 730D for next year's plow day. I think they plowed about 18 acres on Saturday with over ten tractors - anything from an 830D to a 730LP and even a little 330 pulling 1-12". I've plowed a lot of ground with my 620 and always enjoyed every minute of it.
720Deere
04-14-2004 16:53:39
Ask that question and you are going to get many varying answers from both ends of the spectrum. Somebody will tell you that they have all they can handle with 3 bottoms and someone else will say that they pull 5 bottoms with ease.
It all depends on the type of soil, depth of cut, lay of the land and speed at which you want to travel. A properly ballasted 720 should pull 4-14" plows at a depth of 6" to 8" in 3rd gear.
Our ground is quite hilly and can be fairly tight, but we pulled 3-14s with a 520 in 2nd gear for alot of years. I haven't plowed any with my 720 yet, but I know that it is twice the tractor that the 520 is.
Whatever size plow you decide to use, have fun and plow responsibly. I have seen erosion problems that looked like the Grand Canyon created by plowing where you shouldn't.
